8 members (Oswald, Hotrod Lincoln, moparguy, tclederman, 2-Ton, 1955 1 Series, Shade Baby, 1 invisible), 324 guests, and 6 robots.
Topics128,162
Posts1,057,056
Members48,463
Hi guys.
I have a 53 3100 with what I believe is a 1960 235 (if my casting number translations are correct). I currently have a leaky auto-choke BC model that I'd like to replace with a model B manual choke. I have two model B’s but unfortunately the throttle bodies won’t mount up to the intake (the intake studs are slightly wider). Any one know if there is a 1960 throttle body out there that will mate this up, or am I looking at getting another carburetor all together?
Thanks much,
-cj
1953 Chevrolet 3100
The acceleration linkage is similar, so just get a round file and open up the holes a little to fit. Easy one.
"Drugs are money, money is power, power is security." - Kent Heiner
Nedrow population 2212
Carbon footprint family of 2/11 tonnes of CO2/yr
It may come to that. I was hoping they might have used the same carb in 1960 so that the set up wouldn’t look like I had to make it fit. I had Napa, Carquest, and Schucks digging through their parts books yesterday...no avail. Their answer seems to be one of replacement over repair. Where have all the old parts guys gone? wink
1953 Chevrolet 3100
dremel with a stone the metal is real soft it only takes a few minutes thats what i did also
8
8 Offline
Why not take the throttle off the BC and put it on the B. If I recall correctly, the vacuum passages all line up correctly.
-Tim
'51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
