2 members (dt235sd, JW51),
204
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,077 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | I bought a '51 split windsheild, 216 babbit pouding spalsh oiling 1/2 ton with a 54 grill from a guy who said 'heres the original grill, lucky they didn't cut the '51 fenders for the '54 turnsignals.' When I tore down the front clip I realized the front fenders are '54 cause they are indented where the turnsignals on the '54 grill go.
I want to put the '51 grill on to match the rest of the truck, and cause I like it better.
Is the only difference between the '54 and '51 fenders the indentation for the turn signals (that I can fill w/bondo, pound flat or cut/weld/grind/sand)??? Or, do I need to start looking for a set of 47-53 fenders?
Also, does anyone have the lower splash panel for the grill, the one that looks like the upper radiator cover and goes under the grill?
Thanks!
| | | | | Joined: Oct 2005 Posts: 275 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 275 | You should probably start looking for 47-53 front fenders.On the 54 fenders where the grill bolts up to the fender it has a rounded corner kinda beside the headlight and the 47-53 has a square corner so the 47-53 chev grill won't fit with out modifying either the grill or fender.
Somebody correct me if I'am wrong
38 original 48 panel 59 stepside 46 in the back forty
