1 members (Woodcmiami),
72
Mod | | | Forums66 Topics128,031 Posts1,055,433 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 200 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 200 | Does anyone know where I can purchase a clutch fork boot for my 51 1/2ton that will fit? I have two but both are way too big to fit the bellhousing. Thanks for the help.
Mark
1951 Chevy 3100 Some days you get the bear. Some days the bear gets you.
| | | | | Joined: Oct 2003 Posts: 297 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2003 Posts: 297 | have you tried the usual vendors? american classic trucks has them in their on line catalog.
54 3100 w/62 235 "Yosemite Sam" Born a Jay Hawk, raised an Okie and resurrected in Texas!http://community.webshots.com/user/djed50
| | | | | Joined: Sep 2003 Posts: 200 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 200 | djed50
Yes sir I have. The first one came from Chevy Duty and frankly I don't remember where the second one came from. They are both the same size except the second one was a thinner material. I've gone through a few catalogues online and haven't found one yet. Have you got one from american classic? If you have I will call. Thanks dj.
Mark
| | | | | Joined: Apr 2005 Posts: 507 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 507 | Mark, if you have the stock trans, then you can get one from the Filling Station in Lebanon,OR www.fillingstation.com if it is not the stock trans you just need to know what tranny you have, in order to get the right one.
"If it ain't Steel it ain't Real" "Earth the insane aslyum for the rest of the Universe" 41 1/2-ton, a work in progress 68 Shortbed stepside 327/325hp/700R4
| | | | | Joined: Sep 2003 Posts: 200 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 200 | Thanks 41Chevy. I'll give them a call. It's great to have this site and the people on it to share there info.
Thanks again,
Mark
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I think that this problem has been reported before? Does anyone have on their truck a clutch-fork boot that works on an Advance-Design clutch housing? Tim | | | | | Joined: Sep 2003 Posts: 200 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 200 | Thanks Tim,
Well now I am confused. Should there even be a clutch fork boot on an AD bellhousing? What are you all running on your trucks?
Mark
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I bought one from Chevy Duty and one from Chevs of the 40s and neither worked (at the time I bought them, they were both listed for A-D trucks). They did not fit the original clutch housings - I use no clutch boots (but, I would consider using one, if I found one that fit).
Tim. | | | | | Joined: Sep 2003 Posts: 200 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 200 | Tim,
I'm with you. If they didn't have them at the time the truck was new, then that's great. I would use one too, if there is one available that will fit. Anybody have one that fits? If so where did you get it?
Mark
| | | | | Joined: Dec 2005 Posts: 11 Junior Member | | Junior Member Joined: Dec 2005 Posts: 11 | I took the remains of a leather boot out of my 48 GMC bellhousing. I have been told that the early corvette takes the same boot. I havent tried this but maybe it will be of some use to some body. Good Luck Jay
Life expands or contracts in direct proprtion to your courage
I.I.# 4754
| | | | | Joined: Sep 2003 Posts: 200 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 200 | Jay,
The leather boot may have some merit. When we pulled the rear axles and the seals and bearings, the seals had leather. Maybe the old boots were leather. Has anyone else seen leather clutch fork boots on their AD? This really is archeology with a wrench.
Mark
