| | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2004 Posts: 128 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 128 | I'm looking for a known good alignment values for a 52 that has had either a front steer camaro or nova front clip added.
Has anyone got this sorted out? | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I don't think anyone can offer what you are asking for. Unless you can find one that was cut at exactly the same places, and the two frames aligned with each other exactly the same way, someone else's alignment specs are not going to work for your situation.
A better question might be to ask how others have dealt with figuring out the correct alignment for a clipped truck.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | why wouldn't it be just the alignment of the originating vehicle? the entire front clip contains all the 'alignable' bits [usually including the steering box too], assuming it's attached straight and true and isn't sittin on a big rake or something, the front geometry should be whatever it originally was
Bill | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Originally posted by red58: why wouldn't it be just the alignment of the originating vehicle? I think you caught some of the reasons. Its very likely the suspension won't be aligned the same as it was in the original car. Plus the weight might be different, and the wheel base is likely to be different.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | | Anonymous Unregistered | | Anonymous Unregistered | You should use the alignment specs for the donor vehicle as a starting point. A good alignment person will then be able to fine tune the specs for your truck. Be sure to get a report once things are dialed in and keep that in your vehicle records for the next time. | | | | | Joined: Dec 2002 Posts: 3,441 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,441 | I have a 69/70 nova clip in my 39 Coupe... I set the toe in and the camber at the spec for the Nova, seems to work fine... at least i'm not wearing out the tires...
I bought an alignment tool... but if you dont think you can do it... ask the custom tire/wheel bubba who does all the local hotrods...
| | | | | Joined: Sep 2004 Posts: 117 Member | | Member Joined: Sep 2004 Posts: 117 | take it to an old front end guy, he will know where to set it. factory specs are just a guideline. I retired from A lincoln-Mercury Dealer..All I did was front end work. Some young kid with a 4 wheel alignment machine isn't gonna have a clue without the factory specs to put into the machine. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | A competent from end shop can align your front end so it will track true and not dart or wear out tires. The big non correctable thing we run into is people not being aware of the anti-dive factor built into the factory front suspension. In an effort to make the frame grafting "pretty" they upset this angle, sometimes severely. Really not a factor in one that just puts down to the Sonic on saturday night but will definitely unload the rear under hard braking which can be a real bummer in a curve or on less than ideal surfaces.
Evan
