9 members (warlock, Otto Skorzeny, 55shaker, k2handyman, RoadsScholar, Ponchogl, 5 Window 9434, 6inarow, 1 invisible),
97
Mod | | | Forums66 Topics128,048 Posts1,055,626 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 86 New Guy | | New Guy Joined: Jun 2005 Posts: 86 | Our 1953 Chevy resto job is progressing well and the old boy "Baxter," runs like a champ. Yesterday, it was cold enough to pull out the heater knob. All fine for the first five minutes, then steam! Came out under the dash. I closed the heater control, and the steam was slowed and then only vented outside a small amount. Any thoughts on what we may find when we take the heater cover off? I have never messed with one, so I am a probie when it comes to heaters (obviously)! | | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | You probably blew a hole in the radiator in the heater or one of the connections. Are you running a pressure radiator cap? These old heaters were designed to run with a zero pressure radiator cap. | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | Heaters in those old trucks are pretty simple.. just a coil and an electric fan.
Hot engine coolant runs thru the coil all the time (unless you have a manual shutoff valve under the hood or a cable from the inside of the cab running to such a device) when you hit the switch, the electric fan forces air thru the coil and it heats it.
So if this "knob" you pulled is connected to a cable that goes to a supply cut off valve, then my guess is that your heater core has a leak. When you pushed the knob back in, you shut the supply off to the core.. which seems consistant with what you reported happening.
If the "knob" you pulled is actually the electric switch to the blower motor, then maybe it wasn't steam, but smoke?
From what you described, i'd guess either your heater core had a hole in it to start with, or opening the valve introduced some higher than 0 pressure that popped it.
| | | | | Joined: Sep 2000 Posts: 390 Shop Shark | | Shop Shark Joined: Sep 2000 Posts: 390 | My geuss is your heater controll valve is leaking.If you look under the dash and follow the rod the nob is conected to you will see the valve on the fire wall.You should see where anti frezze leaked down when the valve was open.If the heater core were leaking you should see anti frezze under the heater on the passengers side.Get a repacked valve from one of the venders and you should be good to go.Itryed several used ones and all leaked.Ron.
1942 1\2 Ton 1951 1\2 Ton 55 willys cj-5 1954 and 59 Cushman Scooter 1960 Biscayne Sedan 1965 G/10 panel van 1966 C/30 Grizzly Motorhome You know you're a 'Bolter when your daily driver is older than you are... My progress pics | | | | | Joined: Jun 2005 Posts: 86 New Guy | | New Guy Joined: Jun 2005 Posts: 86 | Thanks, everyone! The "knob" was the heater control valve; I did know that. :-( Anyway, when I get back out there to it, I will check the leak. There is a vendor...www.classicheaters.com - seems he can repair all types of cores. Might be of help to someone. | | | | | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | Any radiator shop can repair a heater core. It is just a smaller and simpler version of a radiator.
Mike Barnes 1950 GMC 1-ton pickup
| | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | Ditto to what has been stated above.If you need a core I have the complete unit for a '53.Let me know.Also,it is a good idea to put a ball valve(shut off)on the heater input(just below the thermostat) so you can shut off all hot water going to the core in the summer.AD cabs are hot unless you are under way.Cowl vent open,both vent windows open and pedal to the metal!!!!
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
| | | | | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 |
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | Funny you should mention it, I had my 72 core checked - complete dog. About 10 holes in it. I got the truck with it NOT connected which made me suspicious. The local radiator shop recored it for $55. Btw...your original post inspired me to haul it out. Especially when I have no engine and the seats are out. My ducting is an absolute mess too. Oh well. Call it 'job security'. | | |
