4 members (Jon G, 5 Window 9434, Charles in CA, dt235sd), 54 guests, and 0 robots.
Topics128,049
Posts1,055,635
#196941 01/02/2006 4:39 PM
Our 1953 Chevy resto job is progressing well and the old boy "Baxter," runs like a champ. Yesterday, it was cold enough to pull out the heater knob. All fine for the first five minutes, then steam! Came out under the dash. I closed the heater control, and the steam was slowed and then only vented outside a small amount.
Any thoughts on what we may find when we take the heater cover off? I have never messed with one, so I am a probie when it comes to heaters (obviously)!
#196942 01/02/2006 5:35 PM
You probably blew a hole in the radiator in the heater or one of the connections. Are you running a pressure radiator cap? These old heaters were designed to run with a zero pressure radiator cap.
#196943 01/03/2006 12:01 AM
Heaters in those old trucks are pretty simple.. just a coil and an electric fan.
Hot engine coolant runs thru the coil all the time (unless you have a manual shutoff valve under the hood or a cable from the inside of the cab running to such a device) when you hit the switch, the electric fan forces air thru the coil and it heats it.
So if this "knob" you pulled is connected to a cable that goes to a supply cut off valve, then my guess is that your heater core has a leak. When you pushed the knob back in, you shut the supply off to the core.. which seems consistant with what you reported happening.
If the "knob" you pulled is actually the electric switch to the blower motor, then maybe it wasn't steam, but smoke?
From what you described, i'd guess either your heater core had a hole in it to start with, or opening the valve introduced some higher than 0 pressure that popped it.
#196944 01/03/2006 1:02 AM
My geuss is your heater controll valve is leaking.If you look under the dash and follow the rod the nob is conected to you will see the valve on the fire wall.You should see where anti frezze leaked down when the valve was open.If the heater core were leaking you should see anti frezze under the heater on the passengers side.Get a repacked valve from one of the venders and you should be good to go.Itryed several used ones and all leaked.Ron.
1942 1\2 Ton
1951 1\2 Ton 55 willys cj-5
1954 and 59 Cushman Scooter
1960 Biscayne Sedan
1965 G/10 panel van
1966 C/30 Grizzly Motorhome
You know you're a 'Bolter when your daily driver is older than you are...
My progress pics
#196945 01/11/2006 7:26 PM
Thanks, everyone!
The "knob" was the heater control valve; I did know that. :-( Anyway, when I get back out there to it, I will check the leak.
There is a vendor...www.classicheaters.com - seems he can repair all types of cores. Might be of help to someone.
#196946 01/11/2006 8:28 PM
Any radiator shop can repair a heater core. It is just a smaller and simpler version of a radiator.
Mike Barnes
1950 GMC 1-ton pickup
#196947 01/11/2006 8:41 PM
Ditto to what has been stated above.If you need a core I have the complete unit for a '53.Let me know.Also,it is a good idea to put a ball valve(shut off)on the heater input(just below the thermostat) so you can shut off all hot water going to the core in the summer.AD cabs are hot unless you are under way.Cowl vent open,both vent windows open and pedal to the metal!!!!
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
#196948 01/12/2006 5:06 AM
hope you got it fixed.
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton
My Machine
#196949 01/12/2006 5:07 AM
Funny you should mention it, I had my 72 core checked - complete dog. About 10 holes in it. I got the truck with it NOT connected which made me suspicious. The local radiator shop recored it for $55. Btw...your original post inspired me to haul it out. Especially when I have no engine and the seats are out. My ducting is an absolute mess too. Oh well. Call it 'job security'.
