| | | Forums66 Topics128,026 Posts1,055,404 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 4 Junior Member | | Junior Member Joined: Dec 2003 Posts: 4 | I have been wanting to replace the lever action shocks with tube shocks ,on my 46 pick up. The conversion kit is $280.00 plus shipping.{wow} After reading the tech page. Then I look at those massive leaf spring on this little truck, I have to think, will a tube shock make any difference to the ride?? What do you think?? thanks--- dave | | | | | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | Dave...I wanted to do the same this on my '41...I replaced the rear end on my truck with a late 70's Blazer rear and had to install tube shocks. But your right, I could carry a tank in the bed of that truck and the springs would barely bend. And I did some research on lever action shocks...did you know they last 3 to 4 times longer than tubes and give as good a ride? It appears to be worth it to have your fronts or rear rebuilt (if they need to be!). | | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | I boxed the frame on my 59 1 ton and added rear shocks, didn't make much difference - very stiff springs. But it looks good....  | | |
