1 members (Gray_Ghost), 79 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#196911 01/03/2006 4:20 AM
Junior Member
Junior Member
I have been wanting to replace the lever action shocks with tube shocks ,on my 46 pick up.
The conversion kit is $280.00 plus shipping.{wow}
After reading the tech page. Then I look at those massive leaf spring on this little truck,
I have to think, will a tube shock make any difference to the ride?? What do you think??
thanks--- dave
#196912 01/03/2006 4:55 AM
Dave...I wanted to do the same this on my '41...I replaced the rear end on my truck with a late 70's Blazer rear and had to install tube shocks. But your right, I could carry a tank in the bed of that truck and the springs would barely bend.
And I did some research on lever action shocks...did you know they last 3 to 4 times longer than tubes and give as good a ride? It appears to be worth it to have your fronts or rear rebuilt (if they need to be!).
Steve G.
1942 Chevrolet 1/2-Ton Pickup Truck
#196913 01/03/2006 7:29 AM
I boxed the frame on my 59 1 ton and added rear shocks, didn't make much difference - very stiff springs. But it looks good.... wink
