3 members (Otto Skorzeny, Peggy M, Joe H), 83 guests, and 2 robots.
Topics128,022
Posts1,055,361
Members48,420
#19639 02/19/2004 6:48 AM
Y
Y Offline
I just installed the water pump kit for the later model 235 to fit in my 54 3100. I got it from Chevy Duty. Now i can't seem to get a fan to fit in between the radiator and the new "short" water pump. Any ideas?
1954 Chevy 3100 235
2 Yamaha YSR50's
05 Silverado crew
00 Yamaha TT-R125 Supermoto
#19640 02/19/2004 9:15 AM
That is a problem on some trucks, especially if the fenders or grille have ever been removed. I have a short water pump and pulley on my 261 and I still ended up using an electric fan for clearance reasons. I could have gotten a flex fan to fit but it still would have been too low on the radiator. I am really happy with the 17" 2000 cfm fan mounted on the front of the rad, and I have a thermostatic switch that turns it on and off. It cost me about $100 to do.
For the water pump I didn't bother with the kit, I just found a fomoco 7" pulley that had the same bolt pattern as the chevy pulley, and pressed the hub down on the original shaft and cut it short. It looks stock. It cost me $35 for the water pump and $2 for the pulley.
Paint & Body Shop moderator
#19641 02/19/2004 3:50 PM
Isn't there some adjustment that you can make to the radiator? Now maybe it is just mine but I seem to remeber the Radiator having a flange that sits in a chanel (radiato support) and bolts that adjust how far forward or back it sits.
How much room do you need?
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
#19642 02/19/2004 6:42 PM
i used the chevy duty water pump when i put my 62 engine in my 54 pu. it was a tight fit but did clear. you might be able to move the radiator back enough also - can't remember.
54 3100 w/62 235 "Yosemite Sam"
Born a Jay Hawk, raised an Okie and resurrected in Texas!http://community.webshots.com/user/djed50
#19643 02/20/2004 5:01 AM
I have a '54 and have done the same thing. It's a tight fit, but it works. I installed the water pump and fan and then slid the radiator in place. There's only about 1/4 in. of clearance. I also had to shave some of the blade off so it wouldn't hit the harmonic balancer. Maybe for some reason, the pump you got is not correct. I'll check the length of mine when I go to work tomorrow and give you a spec.
'54 3100-235-T5 trans-12 bolt 3:31
'68 Impala 307/350
'78 Sportster/Original owner
#19644 02/21/2004 4:20 AM
ysrjunkie: I measured from the block to the raditor and it is right at 5.75 in. To the end of the shaft on the pump it's about 5.25 in. So there's about a 1/4 in. between the blade and the radiator. Keep us posted. Good luck.
'68 Impala 307/350
#19645 02/23/2004 5:19 AM
Y
Y Offline
Thanks for the info guys. I thought it would probably be this way and will probably install an electric fan. I've got about an inch and a half between the pump and the radiator. Then if I were able to get a fan on it would be too low.
1954 Chevy 3100 235
2 Yamaha YSR50's
05 Silverado crew
