0 members (),
119
Mod | | | Forums66 Topics128,101 Posts1,056,182 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#19592 10/21/2002 5:27 PM | Joined: Sep 2002 Posts: 2 Junior Member | | Junior Member Joined: Sep 2002 Posts: 2 | Can anyone tell me why, after I have applied the bark several times on my 1948 1 1/2 ton truck, the fluid wants to run out of the breather holes in the top of the master cylinder filler cap?
The brakes are spongy to begin with, and that is the only spot where I detected fluid loss. Thanks for any advice. | | |
#19593 10/21/2002 6:43 PM | Joined: Jan 2002 Posts: 398 Member | | Member Joined: Jan 2002 Posts: 398 | Have you checked the wheel cylinders yet? You might have a siezed one, or maybe a blockage of rust/crud in one of the lines. Just a thought-I'm sure others more "in the know" will chime in. Best of luck Regards, Wannabe
"Don't expect anything and you'll never be disappointed"
#19594 10/21/2002 7:13 PM | Joined: Dec 2000 Posts: 64 Member | | Member Joined: Dec 2000 Posts: 64 | You have air in the lines. To bleed this air out you need some one to help you. Start with the power brake booster [some have 2 bleed ports] then the left front, then right front, left rear, right rear. Make sure the master cyl does nor run out of fluid while bleeding. The helper person needs to pump the brakes till they have a good pedal, hold it till you open the bleeder, then let you know when the pedal is all the way to the floor. You close the bleeder, repeat this till there is not any air coming out the bleeder, then go to the next wheel. As I mentioned before, do not let the master cyl. run out of fluid. I hope this helps you have good brakes.
kdot em3
#19595 10/21/2002 10:23 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | It can be difficult to bleed the air out on the larger trucks.The brake lines are often higher than the master cylinder, complicating the bleeding.Most of us don't own a power bleeder so I have a cheapo alternative.I use a rubber stopper with a tube through the center that fits into the master cylinder opening. An old coffee can with a similar tube soldiered or epoxyied onto the bottom is hung from the steering wheel with a wire. A length a hose connects the can to the stopper.Fill the can with fluid and bleed the brakes as Racecarldad explains. The can keeps the MC full and acts to keep the brake fluid above the level of the brake lines.A friend reported good success by bleeding the brakes with one of those hand held bleeding pumps. Instead of sucking the fluid from the wheel cylinder screw, he uses the pump to force fluid into the bleeder and out through the master cylinder.I have never used a pump ,so I can't say for sure it works. | | |
#19596 10/22/2002 2:13 AM | Joined: Sep 2002 Posts: 115 Member | | Member Joined: Sep 2002 Posts: 115 | You have received some good advice on getting the air out of the system to correct your spongy brakes. No answer on your first problem, though, about fluid running out of the breather holes in the cap.
Each time you press the pedal, a small jet of fluid squirts out the tiny hole in the bottom of the reservoir. In most cylinders, that jet of fluid hits the bottom of the cap. Because of this, caps are made with baffle systems to turn the fluid back into the reservoir. Original GM caps have a stamped sheet steel baffle pressed into the bottom of the cap. Aftermarket caps vary in design, but all have some sort of baffle. Yours is missing or damaged, I'd guess.
Joe | | |
#19597 10/22/2002 2:26 AM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | The other day I had topped off my brake fluid and figured let's feel the pedal. So I did with my hand while my head was still down there and the cap off. A squirt of fluid went straight up passed my ear and missed me by inches.
54 3100 with 235 62 flatbed dump C60 with 261
#19598 10/22/2002 2:33 AM | Joined: Feb 2000 Posts: 203 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 203 | As with Tony, I wondered if the gasket might be missing from the filler hole. | | |
#19599 10/22/2002 9:48 AM | Joined: Jun 2002 Posts: 96 Shop Shark | | Shop Shark Joined: Jun 2002 Posts: 96 | Not sure if mentioned in racecarldad article but if your fluid is new you can attach a small hose to the bleeder and direct to a container for immeadiate resuse. If old fluid is present the hose will stop the fluid going everywhere. Hope this is of assistance.
Send David Hicks home - now! "Better to be wrong and kill no one then right with mass graves" Albert Camus
#19600 10/22/2002 11:50 AM | Joined: Jan 2000 Posts: 125 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 125 | Just wondered, I don't have a bark on my half ton, did that just come on the big trucks?
Grant 1950 Chevy 3100 1952 GMC 150 (In Pieces) 1968 Chevy K20 1966 Shovelhead 1978 BMW 100S
#19601 10/22/2002 1:57 PM | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | Just for everyones information Mighty Vac makes a new LARGE Fluid Extractor that you can buy a Brake fluid addapter for. I got one of these for many reasons ( draining differential, gear box ). Anyways this is a great tool, even used it the other night to test my wiper motor befor intstalling it. This is just a giant vacuum pump with a very large catch container aprox 6 liters. Nice tool!
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
#19602 10/22/2002 2:53 PM | Joined: Sep 2002 Posts: 2 Junior Member | | Junior Member Joined: Sep 2002 Posts: 2 | Originally posted by Grant: Just wondered, I don't have a bark on my half ton, did that just come on the big trucks? First of all, thanks to all of you for your ideas and suggestions. Hopefully this will solve my problem. You have been great, regardless. As for Grant's question, yes the bark is only on the big dogs (actually, that error proves that spellcheck is nothing but a pain in the exhaust pipe, o rthat I am too quick to say okay.) | | |
#19603 10/22/2002 3:59 PM | Joined: Jun 2002 Posts: 96 Shop Shark | | Shop Shark Joined: Jun 2002 Posts: 96 | I know some guys dont go to the lounge but I just posted a thread about brake bleeding that can be done single handed apparently. I guess I should have posted it here.
#19604 10/22/2002 8:10 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Grant, I think you need the dog option to get the bark. They came standard on bigger trucks.
All seriousness aside, I use a 1- man bleeder tool which is a little transparent bottle with a magnet on it and a hose. You connect the hose to the bleeder, open it, and pump until the air comes out. The bottle fills with brake fluid, and you just empty it out (I never re-use mine). It works great and only costs $5 at your flaps. You don't get any fluid on your paint that way.
#19605 10/23/2002 5:53 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Darn it, I spent 99 cents more on my bleeder kit It still works great
#19606 10/23/2002 1:42 PM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | I have been [censored] ever since I read the other thread. I paid $7.99
#19607 10/24/2002 8:19 PM | Joined: Jan 2001 Posts: 230 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 230 | A _magnet_? where's the fun in that ? you're supposed to use an old pop botle and tie some wire around the neck and then make up a loop that goes over the axle and lets the bottle hang where you can easily see the bubbles coming out the hose , then bump it with the bleeder wrench or your elbow , splashing brake fluid all over you and the freshly painted backing plate , etc.....
-Nate There is no problem so difficult it cannot be overcome by generous application of brute force & ignorance
