0 members (), 123 guests, and 8 robots.
Topics128,186
Posts1,057,211
Members48,465
V
V Offline
Well, I just spent some quality time under my '46 the other day. Pulled out my dusty creeper and slid under Norma Jean (my truck's given name). Armed with my trusty grease gun, I gave her my first (and far from the last) greasing. I noticed grease fittings on the top of the brake drums. These appeared to have NEVER been hit with grease. These babies are really rusty, unlike the other fittings on the truck I know from my days owning and servicing roll-off trucks that the brakes need to be greased, but NEVER too much. Should I grease these fittings with the typical one-squirt of grease, or just leave them alone?
Thanks to all. I think that The Stovebolt page is just great!
Regards,
Mark
God wins, every time.
Anonymous
Unregistered
Anonymous
Unregistered
Those sound like the bleeders for the wheel cylinders, you can grease them, but it would be a waste of grease . . .
Welcome. Whenever I get a new truck, I try to get a corresponding shop manual as soon as I can--helps with stuff like this. Nice truk you have.
Buzz'n Half Dozen
Those are bleeders for the wheel cylinders. They colud be sprayed with penetrant and maybe put a little grease around the threads to help then come loose after letting them soak.
NOTE: do not open the bleeder unless you are ready to bleed the brakes or are going to do repairs to the brake hydraulic system.
Are you guy's falling for this? :confused:
I'm really scared now.
Thomas Mott
1949 GMC 250
1957 Dodge COE c-700
1959 Chris Craft 17' w/big journal 327 for more power
