5 members (klhansen, UtahYork, 1955 1 Series, greenie-reddy, dt235sd), 210 guests, and 2 robots.
Topics128,085
Posts1,055,969
Members48,430
#195470 12/15/2005 2:32 PM
Y
Junior Member
Junior Member
Y Offline
Is it posible to get the right kit for my rochester 1bl without the tag? What else could you use to find the carb model?
1951 6400
1954 6100 dump
2 1962 IHC scouts
#195471 12/15/2005 10:32 PM
Throttle body base, behind the choke housing, or below the main body depending on era/model.
Nevertheless, the later "generic" kits apply to most all the 1bbl models, as the internals are basically the same.
#195472 12/15/2005 10:44 PM
Me thinks ya better ask Carb King
Might be a better alternative wink
Regards
