1 members (baldeagle), 37 guests, and 6 robots.
Topics128,014
Posts1,055,327
Members48,419
#19525 11/16/2003 1:29 AM
Fox
Offline
Will a stock 50 radiator cool a 350? Are there any companies out there that make reproduction rads that are setup up for trans lines and such?
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
#19526 11/16/2003 1:46 AM
I would try Walker in Memphis, As a matter of fact I have their catalog down at my shop. I will get it here in a little while and see what they have. As far as your radiator( If you do have the original) cooling a 350 I can't really say but before you spend the BIG BUCKS for a Walker or any other brand I sure would give it a try. I bet some of the old rodders did! I got a Radiator from them for my Forty **** Coupe which
runs a 350/350 and I tell you what , They do build a good radiator but expensive.
Darin Younce
#19527 11/16/2003 2:05 AM
Junior Member
Junior Member
I had mine re-cored with a high efficiency 4 row by a local radiator shop for about $150.00 and got a trans cooler from Summit racing for about $60.00. there is no room for a puller type elec. fan so I'm using a flex fan with good results. I haven't installed A/C yet......???
#19528 11/16/2003 1:56 PM
[img]http://www.tradeincars.com/ebay/nov03/oldtruck/pic00038.jpg[/img]
If this url is correct, it shows a pic of a orig rad with small block chevy. Atleast we do know
now that folks have done this.
Darin Younce
#19529 11/16/2003 1:59 PM
I think its a smallblock F o r d. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#19530 11/16/2003 2:18 PM
Yep, I missed that . How odd a F O R D in a chev
Darin Younce
#19531 11/16/2003 2:23 PM
Still a small block v8 I believe can be cooled by the orig rad With some mods. I just looked
in my Walker book and the radiator with trans lines runs around 570.00 Z series , c series is 468.00 . add around 100.00 for ac .
Darin Younce
#19532 11/16/2003 3:53 PM
Junior Member
Junior Member
I would not use a stock radiator for your 350. The biggest issue you will have is that the 350 operates at higher pressures than the original engine. Also, it may not be as efficient as the newer radiators. I put a 350 in my 1950 and used an aftermarket radiator designed to fit in the same slot. It bolted right to the original radiator frame support!
Richie West
#19533 11/16/2003 6:01 PM
Fox,
I ran a stock '49 radiator with a 350 in my truck for over 10 years without a single overheating problem. This includes driving the truck at freeway speeds, fully loaded up over Snoqualamie pass when I moved from Tacoma to Walla Walla. On one trip, I came via the Vantage bridge through the Hanford area and when I got to Richland, the thermometer on a bank said 104. I know I was plenty hot, but the truck didn't even hint that it might overheat. This is with a manual transmission, no overdrive and a 2.72 (or thereabouts) rear end. It has a pressure type cap on it but it's so old all the writing on it has worn off. Can't be more than a couple of pound though
The radiator even had a couple of tubes blocked off since I had a little accident drilling out spotwelds on the radiator frame.
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'54 Chevy 6400 2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
No Room Left in Shop
#19534 11/16/2003 8:02 PM
Fox
Offline
Thanks for the replies! smile Richie, which company did you get your rad from? Like to take a look.
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
