| | | Forums66 Topics128,263 Posts1,058,348 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#19525 11/16/2003 1:29 AM | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | Will a stock 50 radiator cool a 350? Are there any companies out there that make reproduction rads that are setup up for trans lines and such? | | |
#19526 11/16/2003 1:46 AM | Joined: Nov 2003 Posts: 9 Member | | Member Joined: Nov 2003 Posts: 9 | I would try Walker in Memphis, As a matter of fact I have their catalog down at my shop. I will get it here in a little while and see what they have. As far as your radiator( If you do have the original) cooling a 350 I can't really say but before you spend the BIG BUCKS for a Walker or any other brand I sure would give it a try. I bet some of the old rodders did! I got a Radiator from them for my Forty **** Coupe which runs a 350/350 and I tell you what , They do build a good radiator but expensive.
Darin Younce
#19527 11/16/2003 2:05 AM | Joined: Dec 2002 Posts: 40 Junior Member | | Junior Member Joined: Dec 2002 Posts: 40 | I had mine re-cored with a high efficiency 4 row by a local radiator shop for about $150.00 and got a trans cooler from Summit racing for about $60.00. there is no room for a puller type elec. fan so I'm using a flex fan with good results. I haven't installed A/C yet......??? | | |
#19529 11/16/2003 1:59 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I think its a smallblock F o r d. Brian | | |
#19530 11/16/2003 2:18 PM | Joined: Nov 2003 Posts: 9 Member | | Member Joined: Nov 2003 Posts: 9 | Yep, I missed that . How odd a F O R D in a chev
Darin Younce
#19531 11/16/2003 2:23 PM | Joined: Nov 2003 Posts: 9 Member | | Member Joined: Nov 2003 Posts: 9 | Still a small block v8 I believe can be cooled by the orig rad With some mods. I just looked in my Walker book and the radiator with trans lines runs around 570.00 Z series , c series is 468.00 . add around 100.00 for ac .
Darin Younce
#19532 11/16/2003 3:53 PM | Joined: Oct 2003 Posts: 36 Junior Member | | Junior Member Joined: Oct 2003 Posts: 36 | I would not use a stock radiator for your 350. The biggest issue you will have is that the 350 operates at higher pressures than the original engine. Also, it may not be as efficient as the newer radiators. I put a 350 in my 1950 and used an aftermarket radiator designed to fit in the same slot. It bolted right to the original radiator frame support!
Richie West
#19533 11/16/2003 6:01 PM | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | Fox,
I ran a stock '49 radiator with a 350 in my truck for over 10 years without a single overheating problem. This includes driving the truck at freeway speeds, fully loaded up over Snoqualamie pass when I moved from Tacoma to Walla Walla. On one trip, I came via the Vantage bridge through the Hanford area and when I got to Richland, the thermometer on a bank said 104. I know I was plenty hot, but the truck didn't even hint that it might overheat. This is with a manual transmission, no overdrive and a 2.72 (or thereabouts) rear end. It has a pressure type cap on it but it's so old all the writing on it has worn off. Can't be more than a couple of pound though
The radiator even had a couple of tubes blocked off since I had a little accident drilling out spotwelds on the radiator frame.
'38 Chevy 1-1/2 ton '49 Chevy 1/2 ton '54 Chevy 6400 2 ton '55.2 GMC 3/4 ton '56 GMC 1-ton
No Room Left in Shop
#19534 11/16/2003 8:02 PM | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | Thanks for the replies!  Richie, which company did you get your rad from? Like to take a look. | | |
