8 members (Peggy M, DaveV, 2-Ton, TUTS 59, JW51, walter74, moparguy, 1 invisible),
159
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,055,955 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2003 Posts: 285 Shop Shark | | Shop Shark Joined: Nov 2003 Posts: 285 | I recently had my 18' auto hauler trailer painted and noticed the chrome rims on the trailer got some paint overspray (the trailer was painted with automotive paint). I have tried both paint thinner as well as denatured alcohol to remove it, but neither seem to do the job. Any suggestions on what would be the best to use, that would not harm the chrome finish? (Note: taking the trailer back to the guy who painted it is not an option) | | | | | Joined: Apr 2005 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 38 | Hi, When you say paint thinner do you mean mineral spirits? I have used both gasoline and lacquer thinner to remove over spray from chrome wheels.
Disclaimer: use outside dont smoke dont get any on paint you wanna keep!
Bill | | | | | Joined: Nov 2003 Posts: 285 Shop Shark | | Shop Shark Joined: Nov 2003 Posts: 285 | Thanks Bill--was thinking of using gas. Yep, tried mineral spirits but with no luck. Would the lacquer thinner be better? Ref your disclaimer: Trailer is outside, I don't smoke, and aware of getting anything I use on other than the chrome.  But darn good advice!!! PS--So how is everything in the "Star City"? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Brian,
Try lacquer thinner and do not get it on any paint, rubber, or organic-based surfaces. It seems to e able to eventually dissolve or soften any paint. Wear gloves but be careful because it also seems to eventually dissolve protective gloves.
You should still be able to buy it in VA.
Tim | | | | | Joined: Nov 2003 Posts: 285 Shop Shark | | Shop Shark Joined: Nov 2003 Posts: 285 | Thanks Tim-appreciate the reply. Yep, think they might have that stuff here in VA!  | | | | | Joined: Mar 2005 Posts: 14 Junior Member | | Junior Member Joined: Mar 2005 Posts: 14 | Another thing that works beautifully for removing overspray and cleaning chrome and glass is OOOO grade steel wool. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Brain56, I have used this successfully on over spray on a painted truck..maybe it would work on your rims! http://www.sjdiscounttools.com/megc2000.html Stuart | | | | | Joined: Mar 2005 Posts: 94 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 94 | I've noted that gasoline works very well for removing paint. I have the bubbled up paint on my running board to prove it. -Chris
1953 Chevrolet 3100
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | You're an adult and can do as you wish but the news is full of stories about people disfigured or killed using gasoline for anything but it's intended use. Lacquer thinner would be my first choice, acetone my second. Lacquer thinner will remove most paints, acetone will remove those that lacquer thinner won't touch. As you found out mineral spirits are only good on uncured paint.
| | | | | Joined: Nov 2003 Posts: 285 Shop Shark | | Shop Shark Joined: Nov 2003 Posts: 285 | A lot of good replys here and thanks to everyone for their input. Believe I may try the lacquer thinner first, and maybe even use the 4-0 steel wool (great idea there!) for what the thinner may not get. There isn't a LOT of overspray, but main thing I did not want to use anything that would harm the chrome rims. Again, thanks for your advice. The trailer itself looks like new, but will look even nicer once I get the rims cleaned.  | | | | | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | gasoline works, but be careful. laquer thinner is a good idea as well. i have used gas the one time it happened to my old truck's rims.
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | | | | Joined: Apr 2005 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 38 | Brian,
The Star is still on he hill...where are you?
Laquer thinner is available at Lowes, Home Depot, even Advance Stores.
Yes! Gasoline is very dangerous so is laquer thinner.
Bill | | | | | Joined: Jan 2006 Posts: 9 Junior Member | | Junior Member Joined: Jan 2006 Posts: 9 | Brian, while lacquer thinner will, with a lot of rubbing, remove the overspray from your chrome rims, I prefer the triple O steel wool way because it is less dangerous to your skin and your lungs...there are clay cleaners on the market for removing overspray, and there is a product made by AmWay that I used [haven't seen it in years, my 2nd wife sold the stuff], a white chalky stuff that you touched with a wet cloth and it removed overspray, resin, acid rain, and anything else from windshield glass and chrome bumpers. Besides, with lac thinner you could really do some damage if it got spilled. good luck on cleaning your rims.....the old restorer.....LamarB
70 C30 Wrecker
| | | | | Joined: Dec 2004 Posts: 56 Member | | Member Joined: Dec 2004 Posts: 56 | howdee Brian!! a product i use a lot for minor cleanup type jobs is called "OOPS"... i comes in several sizes and can be found at walmart; advance store; etc... it is made just for that type of thing as well as labels; tar; road grime; dead bugs; etc... its also great for cleaning up windshield sticker residue; i use lacquer thinner too but i like to be sure it won't act as a solvent and damage my paint; you shouldn't have much problem on chrome though... best of luck... bill w. | | | | | Joined: Nov 2005 Posts: 146 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 146 | ok. i have one for ya how about brake fluid. wont hurt anything other then paint. i even used it on my plastic gauge lense on my 56 pontiac ambulance. | | | | | Joined: Jun 2002 Posts: 272 Shop Shark | | Shop Shark Joined: Jun 2002 Posts: 272 | Use the clay the link pointed you too. virtually risk free. you can get a similar product called Clay magic at any autoparts store that sells wax. | | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | Goof off, scotchbrite, chrome polish. | | | | | Joined: Mar 2005 Posts: 284 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 284 | Rubbing compound mixed with a little water and very fine steel wool.Then polish the rims | | | | | Joined: Jan 2006 Posts: 17 Junior Member | | Junior Member Joined: Jan 2006 Posts: 17 | Brian,
I have used airplane paint stripper on chrome to remove old paint. It seemed to work fine and didn't hurt the chrome. Just let it sit on the paint for a few minutes to soak in well, then wipe and or scrub it off with very fine steel wool.
Just my 2 cents worth.
John Knight 40 Chev (Rat) project for my 16 year old daughter
John M. (Marc) Knight VTCI #33786 Thunderbirds, 64s, 57, 2002 40 Chev Truck (Rat) project for my 16 year old daughter Bountiful, UT
| | | | | Joined: Feb 2005 Posts: 199 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2005 Posts: 199 | I like the cleaning clays on chrome,anodized aluminum and glass for removing overspray.Griots Garage makes a really good clay just for this purpose. I always follow any polish such as clay with a good coat of wax. Hobert
"The Lord is my shepherd"
| | | | | Joined: Nov 2003 Posts: 285 Shop Shark | | Shop Shark Joined: Nov 2003 Posts: 285 | Thank you all for your informative remarks--sure now I will make the right choice in getting those rims clean.  | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | as a side note on keeping rims somewhat 'polished'!! an old rod trick - try using (rubbing) tin foil's shinny side and fill in those pitted areas
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
