2 members (Hanks custodian, TooMany2count), 102 guests, and 0 robots.
Topics128,134
Posts1,056,403
Members48,441
#195173 12/10/2005 1:50 PM
I just put the CPP disc brake conversion kit (5 3/4" bolt pattern) on my 49 3100 1/2 ton truck. If anybody has done this conversion, what size rims and tires did you use? Thanks in advance
Always get a 2nd opinion, especially if I am the source of the 1st opinion.
#195174 12/10/2005 6:18 PM
I used the Chevy Duty kit, which may be slightly different. I used 15x8 wheels and some wide radial tires.
You say the pattern is 5 3/4". I think you meant 5 x 4-3/4 which is the common Chevy car pattern from the 50's up until front drive.
There is a second GM pattern used on some larger Chevy cars which is 5 x 5 like a '72 to '87 1/2-ton pickup.
You can probably use almost any 5 x 4-3/4 wheel. Which one is best depends on what you want to achive.
#195175 12/11/2005 4:37 PM
You are correct about the 5 X 4 3/4" pattern. I was interested in the (minimum) rim size that would clear the calipers. Cpp said caliper size was for the medium size GM (77 camaro). Rotor size was 71-79 camaro. Thanks in advance.
#195176 12/12/2005 1:58 AM
I'm sure a 14" wheel will fit a Camaro rotor.
#195177 12/12/2005 12:38 PM
A stock 14" 74 nova rim with front disc brakes fits. A stock 14" 74 nova rim with front drum brakes will not fit. Got these rims from a buddy for reference.
Thanks OldSub.
#195178 12/12/2005 8:52 PM
if its the 5 x 4 3/4 you can also use rims of S10 pickups blazers jimmys and sonomas also my 1985 Olds Toronado (front wheel drive) had 5 x 4 3/4 rims i used the steel rims of the toro and put them on my 90 S10 blazer the aluminum rims look to nice on my very rusty S10
Nate
Link to my photobucket for pics of my vehicles
http://s238.photobucket.com/albums/ff17/OldIronChevy/
#195179 12/15/2005 1:20 AM
15'' jeep 6 lug rims work
I have 11' rotors and disc's on my 51 3100 w/ stock hubcaps
http://www.speedprint.com/Deves50/hubcapclips.php
Jim & Caroline
#195180 12/16/2005 4:22 AM
Your rims have to be made for disc brakes. The older rims will not clear the piston housing. Chevy made the change in 71 on pickups, and went to a 5 bolt pattern. I would go with either a 15 or 16" rim.
Fred
52 3600
69 C-10
