3 members (68ironhead, 49nut, 1 invisible), 49 guests, and 1 robot.
Topics128,049
Posts1,055,691
i am trying to source the hanger that holds the steering column at the firewall. the one PO installed is very loose and the whole column has about an inch of play... also, what might be the best way of installing this? I'd rather not have to remove the column...
thanks in advance
anyone? I have tried searching catalogs and online stores but im not even sure what this part is called. if someone could just tell me the name of this part i would really appreciate it.
Troy are you talking about the angled bracket that attaches w/3 bolts & is held by a clamp? Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
im not sure whats supposed to be there. its a 63 truck not sure if column is original or not.there is a hole at the firewall that the column passes through. this hole is bigger than the column.there is a bracket. its one peice and has a bolt on either side bolting to the firewall. this bracket is smaller than the hole in the firewall but still not a snug fit. darn... this is hard to explain! haha
look at my horrible drawing for more details
http://img.photobucket.com/albums/v619/theyownus/bad.jpg
i can take some pics and post them tomorrow if the drawing dosent help. thanks for the response though
The OE bracket kinda looks like a foot, has 3 bolts to firewall & a semi-circle "foot" that is clamped to the column. The bolts are above the fot part. Brian
