| | | Forums66 Topics128,048 Posts1,055,664 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 227 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 227 | i am trying to source the hanger that holds the steering column at the firewall. the one PO installed is very loose and the whole column has about an inch of play... also, what might be the best way of installing this? I'd rather not have to remove the column...
thanks in advance | | | | | Joined: Jul 2005 Posts: 227 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 227 | anyone? I have tried searching catalogs and online stores but im not even sure what this part is called. if someone could just tell me the name of this part i would really appreciate it. | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Troy are you talking about the angled bracket that attaches w/3 bolts & is held by a clamp? Brian | | | | | Joined: Jul 2005 Posts: 227 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 227 | im not sure whats supposed to be there. its a 63 truck not sure if column is original or not.there is a hole at the firewall that the column passes through. this hole is bigger than the column.there is a bracket. its one peice and has a bolt on either side bolting to the firewall. this bracket is smaller than the hole in the firewall but still not a snug fit. darn... this is hard to explain! haha look at my horrible drawing for more details http://img.photobucket.com/albums/v619/theyownus/bad.jpg i can take some pics and post them tomorrow if the drawing dosent help. thanks for the response though | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | The OE bracket kinda looks like a foot, has 3 bolts to firewall & a semi-circle "foot" that is clamped to the column. The bolts are above the fot part. Brian | | |
