0 members (), 254 guests, and 2 robots.
Topics128,094
Posts1,056,066
Members48,433
#193672 11/16/2005 10:55 PM
Junior Member
Junior Member
This question has probably been asked 100 times but has anyone found the perfect rearend that bolts into the chevy 1/2 ton. I have the transmission out of a 1955 chevy four speed and have access to my neighbors junk yard thats full of posibilitys. thanks for any response.
doug
#193673 11/16/2005 11:09 PM
Seems like i've read that a 70's Nova was a just about dead on match as far as width was concerned, but it still involved some moving of the springs or something.
As far as direct bolt in replacement, I haven't heard of one (besides another '50 1/2 ton rear end)
#193674 11/16/2005 11:17 PM
Junior Member
Junior Member
yeah i've heard the nova rear end is probably the closest match some where i read you have to swap the springs end for end. my truck has the overload springs and has some funky spring perch that is mounted on the front of the axle.
#193675 11/16/2005 11:18 PM
Junior Member
Junior Member
#193676 11/17/2005 4:47 AM
That funky spring perch is because the '50 has a torque tube drive line. That '55 4-speed is probably an open drive setup.
What is this truck going to be when its finished? If its going to be used as a truck a '55 1st series rear is an easy swap and a good choice. If you want great mileage (okay, maybe only better mileage) you want to make sure you get a gear ratio that gives that. If you are drag racing you want something deeper.
I put a '73 Chevelle rear under my '55 1st and have been very happy with it. I had to trim the coil spring and 4-link stuff off and weld spring pads on, but its worked very well for several years now.
#193677 11/17/2005 6:10 PM
Junior Member
Junior Member
steve, thanks for your input. the four speed is out of a 2nd series 55. so is the 54/55 1st series a different gear ratio, that would allow better highway speed? or would find a rearend out of a car? the truck is going to left stock 235 6 volt just trying for better speed.
doug
