0 members (), 102 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#19332 03/07/2002 6:36 AM
Is this worth doing? Mine appear to be fine since the truck sat evenly on both sides before I ripped it all apart. Plus, it costs $160 per side to get them re-arced! Thanks!
#19333 03/07/2002 2:27 PM
If it ain't broke, don't fix it.
Bill M
53 GMC Hydra-Matic
Home Page
http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#19334 03/07/2002 4:36 PM
Does a machine shop re-arc springs or who does?
#19335 03/07/2002 6:16 PM
A good truck spring shop will re arch your springs..
Bill M
53 GMC Hydra-Matic
Home Page
#19336 03/08/2002 3:27 PM
At $160 per spring, I would check Eaton Detroit Springs and ESPO for the cost new. If you ask (and if they listen), Eaton will set up the springs to look original.
http://www.eatonsprings.com/
http://www.espo.com/
Or, check out Chevy Duty, Jim Carter, Chev's of the 40's (or many other parts dealers).
Of course, if they ain't broke (or lopsided), do not mess with what you have.
Tim
#19337 03/08/2002 9:05 PM
Here in Phoenix, they charge $100 per side, so you may be able to find a better price than that if you shop around. That quote assumes, however, that the springs are already off the truck.
I also debated the same question as you, and finally decided there was no point in getting them re-arched if the truck sat fine before.
Ed
#19338 03/09/2002 6:14 AM
I also debated rearcing the springs vs replacement. Local spring shop told me they could do the job in 1/2 day for about $300, and I didnt have to remove the springs myself.
I then called EATON springs and talked to them. They told me that there are 2 ways to rearc springs, cold hammer or using heat (forget actual term they used) They said cold is quick and cheap but springs will lose there new arc in a few months. Most spring shops are not set up for heat arcing springs.
My springs decided for me. The left leaves began to break a few weeks after a brutal desert outing. I purchased a new set of springs from eaton for about $350, including new bushings. They sold me " rod ride" springs with teflon buttons and tailored the springs to my needs (stock height with rod ride). The truck sits level, and rides as good as it did before. (I had teflon liners on old set. ) THe best part is the springs are new, not 40+ years old.
#19339 03/10/2002 4:13 PM
Anonymous
Unregistered
Anonymous
Unregistered
i had a set re-arced for my 53 3600. i forget what i paid. they used the oven method. i am not satisfied and will never do it again. buy new if you can afford, or replace with good used.
