6 members (Millenimech, mason86, delky, UtahYork, Otto Skorzeny, 1 invisible), 65 guests, and 3 robots.
Topics128,030
Posts1,055,424
Members48,422
#192894 11/06/2005 9:32 PM
Hi Guys --
I am trying to find out is this steering wheel from a 1968 Belair will fit my 1970 C/10
web page
I'd love to use it. I need a better one than i have, and this one is pretty cool.
Boo
We don't need no stinking V-8s!!
#192895 11/06/2005 9:44 PM
The splines and diameter are the same on your truck wheel and the car wheel, but I don't know the diameter of the outside of the inner hub of either wheel, so whether it'll match up with the column cosmetically, I can't say. Another thing to watch out for is the offset. The car wheel is going to be closer to you than your truck wheel, because it is deeper. Things to consider.
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass.
Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
