| | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 158 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 158 | Starting tear down of my '51 half ton.
Door hinges aren't cooperating. I was going to take the hinges with the doors, just undoing the three bolts that hold each hinge into the cab. But on a couple of the bolts, the nuts are spinning with the bolt. I'm assuming these were once tacked in place -- I don't see a way to access the backside with a wrench.
Tips?
I'm afraid I'll tear the hinges up by the time I get them apart.
Cheers, mark. '51 KY 3100 | | | | | Joined: May 2004 Posts: 204 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 204 | Mark,
I just had the same thing happen. On the passengers side on the top hinge the bottom left hand bolt would just spin. So I took the complete door off and used a chisel the knock the head off the bolt. I got lucky because I can reach the back of the nut through the heater opening.
On the drivers side the hinge pins worked their way partially out and I had the drive them all the way out before the hinges would come out.
All said this took me a couple of nights work just to get the hinges off.
Good Luck! Aaron | | | | | Joined: Feb 2004 Posts: 29,747 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,747 | Sometimes it's best to drill the heads off the screws to release the hinges. Don't go too deep, or it gets difficult to remove the remaining piece of the screw. Of course, if the nut is spinning, it's probably going to be necessary to replace the whole assembly anyway. Jerry
