0 members (),
54
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 36 Apprentice | | Apprentice Joined: Aug 2004 Posts: 36 | I have been havig a problem with my clutch petal arm hitting the floor board, is there an ajustment that can be made or do I just use my breaking bar and bend it? anyone had that problem? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | check yer cab mounts, if things are not quite as designed the pedal arms may just not be centered in the holes - most common cause
Bill | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Sounds like you have some collapsed cab mounts...time to slide under the truck and check it out. | | | | | Joined: Aug 2004 Posts: 36 Apprentice | | Apprentice Joined: Aug 2004 Posts: 36 | Is it hard to change them as I know they have never been changed.I know they are not expensive however jacking up the cab sounds like a big job.I took a crow bar and bent the arm down now it is not hitting anymore. I have had this problem before and would just rejust the arms both brake and clutch, I still want to chnge thoe mounts though. | | |
