2 members (Leo, GRNHydra), 84 guests, and 2 robots.
Topics128,060
Posts1,055,837
Members48,427
#191685 10/30/2005 12:55 AM
Apprentice
Apprentice
I have been havig a problem with my clutch petal arm hitting the floor board, is there an ajustment that can be made or do I just use my breaking bar and bend it? anyone had that problem?
#191686 10/30/2005 2:16 AM
check yer cab mounts, if things are not quite as designed the pedal arms may just not be centered in the holes - most common cause
#191687 10/30/2005 3:12 AM
Sounds like you have some collapsed cab mounts...time to slide under the truck and check it out.
1954 GMC De Luxe COE
#191688 10/30/2005 3:28 PM
Apprentice
Apprentice
Is it hard to change them as I know they have never been changed.I know they are not expensive however jacking up the cab sounds like a big job.I took a crow bar and bent the arm down now it is not hitting anymore. I have had this problem before and would just rejust the arms both brake and clutch, I still want to chnge thoe mounts though.
