0 members (),
102
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 96 Shop Shark | | Shop Shark Joined: May 2005 Posts: 96 | Wich non original rear axle accepts stock 6 bolts wheels of a Chevy 1942 1/2 pickup. (mainly to improve highway perf.
Cheers | | | | | Joined: Sep 2005 Posts: 254 Shop Shark | | Shop Shark Joined: Sep 2005 Posts: 254 | the 6 bolt pattern is 6 x 5 1/2 which is the bolt patter on all chevy/gmc pickups that have 6 bolt rims and it would be any axle out of a 1/2 ton 2wd (1970 and older) or any 1/2 ton 4wd i'd sugest getting a rear end out of a 1973-1987 4wd 1/2 cause they're is plenty out there for the two axles used in the those year (corp 12 bolt and corp 10 bolt) | | |
