5 members (55shaker, 52Carl, fonz8261, 78buckshot, RoadsScholar), 98 guests, and 4 robots.
Topics128,100
Posts1,056,515
Members48,448
I can't get my harmonic balancer off of my 49 216. I've used a harmonic balancer/steering wheel puller and the only thing i've accomplished is breaking a bolt off in the pulley. i think i can get what's left of that bolt out through the back side. Anyhow, what can i do to get it off? I'm lost. I'm pretty sure of how it SHOULD come off... but it's just not happening.
Get the broken bolt out and use grade 8 bolts for the puller, or whatever hardened bolts you can find at your local jobber that will fit. If it still doesn't move try heating it with a propane torch, might destroy the balancer but it'll be off anyway. Sometimes ya gotta do what ya gotta do! I have a 54 with just a pressed on HB with no retaining bolt. Mine practically fell off, and that's a whole 'nuther problem!
This might seem silly, but are you sure you are using the puller correctly. Mine has a flat side and a side with a bulge in the center. Anyone would think I would have sense enough to know that the head of the bolt should go against the flat side, but I didn't and broke several bolts before I came to my senses. Once I did that the balancer came right off.Allen
Start by soaking the crank snout a day or two with a good penetrating oil. Kroil, PBblaster are two of the best and usually available locally. You can probably get the bolt out with a left hand drill bit.
When you're ready to try again, use anti-sieze on the bolt and balancer threads. If you break another bolt, the anti-sieze will make it easier to remove. And the balancer threads will load more uniformly. Use grade 8 bolts, be sure they are screwed in evenly so the load is distributed. If you have a strong U.S. made puller, use an impact wrench. If no impact, smack the end of the puller with a 3 lb. hammer when it is down tight.
As stated, use heat only if you have to. Too much will cook the rubber inside the dampner. There's a fine line as to how much heat is too much.
I've been using a good puller since high school, seems like it's 100 years old. wink With grade 8 bolts, I haven't broken any bolts, but did pull the threads out on one. Went to a bigger bolt and it came right off. But now I have probably jinxed myself. eek
Fred
52 3600
69 C-10
When we pulled the HB off my 235 it took a lot of pressure on the puller, but it finally came loose with a loud bang. They are a press fit and take a bit of coaxing.
See my 1940 Canadian GMC:
http://community.webshots.com/user/ndnchf
Fred's right, use a good puller and make sure that you tighten the puller evenly, put some strain on the balancer and then give it a smack with a hammer, should come right off.
"If it ain't Steel it ain't Real"
"Earth the insane aslyum for the rest of the Universe"
41 1/2-ton, a work in progress
68 Shortbed stepside 327/325hp/700R4
thanks guys.... wish me luck i'm heading to the garage now to give it a better try.
When I took the balancer off my 261 the treads in the balancer were no good, so I put the bolts all the way through the balancer and placed flat washers and a nuts on the back side and then I was able to remove the HB with my puller.
1954 GMC 1/2-ton Longbed
1971 Pontiac LeMans Sport
got it completed, thanks..... now how do i get that plastic gear off the camshaft and set the camshaft free?....
The gear is a press fit. If you're just replacing the timing gears you'll have to have the old one removed and the new one installed with a press. I bought a new cam, gear set and thrust bearing and I had the machine shop that I used to rebuild my motor install them for me.
