0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#190625 10/03/2005 5:48 PM
Junior Member
Junior Member
Hi Guys,
Glad I found this site, I think it will be a big help while trying to restore my '52 GMC 3/4 ton.
I have a question on brake conversion kits. All that I have seen are for either a 5 or 6 lug hub, my '52 has 8 lugs. Do I need to change my hubs to one of these and if so where would be a good place to get them? I know this is altering rather than restoring but I think the safety outweighs keeping it original.
Thanks in advance
Eng12
#190626 10/03/2005 7:02 PM
Welcome aboard.
I don't think there are kits for the 3/4 tons and the ones for 1/2 ton won't fit.
At the very top of the page is a row of links. Click on "search" and enter "3/4-ton disc brakes". This has been discussed here before.
#190627 10/03/2005 7:15 PM
Unless you are going to be hot-rodding at high speeds and riding bumpers you could save a lot of time and money and still be safe by installing a dual chamber master cylinder. I'd sure hate to give up the big wheels and hubcaps if you. The big wheels are what makes them cool.
Mike Barnes
1950 GMC 1-ton pickup
#190628 10/03/2005 10:02 PM
Only realistic way is to put 1/2 ton suspension under the truck. Some have cut and welded a late model straight axle, but it is not recommended for the average home shop welder.
Fred
52 3600
69 C-10
#190629 10/04/2005 3:10 AM
Its possible to adapt disks from a modern 3/4-ton to the stock hubs, and then make your own caliper bracket. Looks like a lot of work...
