| | | Forums66 Topics128,030 Posts1,055,421 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2005 Posts: 11 Junior Member | | Junior Member Joined: Sep 2005 Posts: 11 | Hi Guys, Glad I found this site, I think it will be a big help while trying to restore my '52 GMC 3/4 ton.
I have a question on brake conversion kits. All that I have seen are for either a 5 or 6 lug hub, my '52 has 8 lugs. Do I need to change my hubs to one of these and if so where would be a good place to get them? I know this is altering rather than restoring but I think the safety outweighs keeping it original.
Thanks in advance Eng12 | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Welcome aboard.
I don't think there are kits for the 3/4 tons and the ones for 1/2 ton won't fit.
At the very top of the page is a row of links. Click on "search" and enter "3/4-ton disc brakes". This has been discussed here before. | | | | | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | Unless you are going to be hot-rodding at high speeds and riding bumpers you could save a lot of time and money and still be safe by installing a dual chamber master cylinder. I'd sure hate to give up the big wheels and hubcaps if you. The big wheels are what makes them cool.
Mike Barnes 1950 GMC 1-ton pickup
| | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Only realistic way is to put 1/2 ton suspension under the truck. Some have cut and welded a late model straight axle, but it is not recommended for the average home shop welder.
Fred 52 3600 69 C-10
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Its possible to adapt disks from a modern 3/4-ton to the stock hubs, and then make your own caliper bracket. Looks like a lot of work...
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
