| | | Forums66 Topics128,088 Posts1,055,993 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2002 Posts: 7 Junior Member | | Junior Member Joined: Apr 2002 Posts: 7 | hey, anyone out htere know if the tri 5 gm car power steering gear boxes are the same as on the trucks? | | | | | | Anonymous Unregistered | | Anonymous Unregistered | I doubt they are as the 55-57 cars had independent suspension and the trucks had solid axles. Don't think the 55-59 trucks came with a power steering option but not positive. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | "gear box"? the TF power steering consists of a pump on the back of the generator, a control valve in place of the drag link, and a'power cylinder' - otherwise the 'gear' is the same as non-power - the car has a totally different suspension/steering, but the pump on the generator's no doubt the same, so no ... can't swap car power steering into a truck
Bill | | |
