5 members (Wally / Montana, Chris's 46 / 515, mick53, Stovebolt48, 1955 1 Series), 133 guests, and 3 robots.
Topics128,189
Posts1,057,337
Members48,469
#19018 11/21/2004 3:06 AM
Junior Member
Junior Member
What's a good replacement for a single barrel Rochester B for a 55.1 235 engine? Bob
#19019 11/21/2004 3:48 AM
A Carter YF works fine for me! You can get them with an automatic choke, or already configured for a cable choke and a cable throttle.
#19020 11/22/2004 2:45 AM
Junior Member
Junior Member
I've heard that a YF will work but I understand that there is one for the 216 and one for a 235..Which numbered YF do you use for a 55.1 235 ? Thanks Bob
#19021 11/22/2004 3:03 AM
Carburetion specialist
Bob - use the "search" function, and use this criteria:
Carter YF carburetors Chevrolet
This topic was posted in May this year, and should answer your question.
Jon.
The Carburetor Shop
#19022 11/22/2004 3:47 AM
Junior Member
Junior Member
Thanks 3100 Rule and Carbking! Bob
#19023 11/22/2004 9:14 PM
Hey Stovebolt staff!!
we should snark that carbking post about Carter carbs that match (from may) and put them in the FAQ!
-Mike R.
#19024 11/24/2004 6:41 PM
My 54 3100 came to me with an automatic choke set-up and a bad carb. Did some research and found that I actually had a carb for a 54 Belair. A 54 Belair 235 single barrel Rochester works fine. Ordered and received mine through NAPA. Was in a hurry and also ordered one from KOI Parts Stores and another from AutoZone. Received all in four days, kept the best and sent two back w/out a re-stocking charge. Installed and it runs GGGGREAT!!
Bruce (I love My Truck) Miller
1954 5 Window 3100 Chevy Pickup - Driver
1929 **** Model A Pickup - Restoration
