| | | Forums66 Topics128,190 Posts1,057,339 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#19018 11/21/2004 3:06 AM | Joined: Feb 2004 Posts: 15 Junior Member | | Junior Member Joined: Feb 2004 Posts: 15 | What's a good replacement for a single barrel Rochester B for a 55.1 235 engine? Bob | | |
#19019 11/21/2004 3:48 AM | Joined: Oct 2003 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2003 Posts: 66 | A Carter YF works fine for me! You can get them with an automatic choke, or already configured for a cable choke and a cable throttle. | | |
#19020 11/22/2004 2:45 AM | Joined: Feb 2004 Posts: 15 Junior Member | | Junior Member Joined: Feb 2004 Posts: 15 | I've heard that a YF will work but I understand that there is one for the 216 and one for a 235..Which numbered YF do you use for a 55.1 235 ? Thanks Bob | | |
#19021 11/22/2004 3:03 AM | Joined: Nov 2002 Posts: 2,774 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,774 | Bob - use the "search" function, and use this criteria:
Carter YF carburetors Chevrolet
This topic was posted in May this year, and should answer your question.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | |
#19022 11/22/2004 3:47 AM | Joined: Feb 2004 Posts: 15 Junior Member | | Junior Member Joined: Feb 2004 Posts: 15 | Thanks 3100 Rule and Carbking! Bob | | |
#19023 11/22/2004 9:14 PM | Joined: Jul 2003 Posts: 85 Member | | Member Joined: Jul 2003 Posts: 85 | Hey Stovebolt staff!!
we should snark that carbking post about Carter carbs that match (from may) and put them in the FAQ!
-Mike R. | | |
#19024 11/24/2004 6:41 PM | Joined: Nov 2003 Posts: 113 Member | | Member Joined: Nov 2003 Posts: 113 | My 54 3100 came to me with an automatic choke set-up and a bad carb. Did some research and found that I actually had a carb for a 54 Belair. A 54 Belair 235 single barrel Rochester works fine. Ordered and received mine through NAPA. Was in a hurry and also ordered one from KOI Parts Stores and another from AutoZone. Received all in four days, kept the best and sent two back w/out a re-stocking charge. Installed and it runs GGGGREAT!!
Bruce (I love My Truck) Miller
1954 5 Window 3100 Chevy Pickup - Driver 1929 **** Model A Pickup - Restoration
