| | | Forums66 Topics128,078 Posts1,056,039 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#18939 04/03/2005 1:26 AM | Joined: Jun 2004 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 37 | I can't remember if the coil spring that fits over the oil shaft in the inside of the canister goes on the bottom of the cartidge or the top. Any help is appreciated.
My rule of life: You can have anything you want; you just can't have everything you want.
#18940 04/03/2005 1:37 AM | Joined: Jan 2005 Posts: 26 Junior Member | | Junior Member Joined: Jan 2005 Posts: 26 | | | |
#18941 04/03/2005 1:42 AM | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | You're talking about the canister-type filter with the replaceable cartridge, right? The spring goes into the canister first, then the piece that pushes the filter cartridge up against the engine block. If the spring holds the cartridge down, oil will simply bypass the filter, and no filtration will be accomplished. Of course, the fliter lasts a long time that way! Jerry
#18942 04/04/2005 2:24 AM | Joined: Jan 2005 Posts: 26 Junior Member | | Junior Member Joined: Jan 2005 Posts: 26 | Jerry,
Michael again. I have the cannister tyoe filter that is separate from the engine and has a hose in and a hose out. On these, where does teh spring go? I have always put it on top of the repaceable filter.
Michael | | |
#18943 04/04/2005 2:56 AM | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | That's right, Michael. I was thinking of the filter on driver's side bottom of the V-8, that's in the steel can. The bypass-type filter that has oil lines running to it is held toward the bottom of the canister with the spring on top! I guess we were comparing apples and oranges! Jerry
