| | | Forums66 Topics128,035 Posts1,055,566 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2005 Posts: 112 | i know how to drive a three on the tree but i was thinking about changing to a 3 speed od how do you activate od or does it work like a torque converter or switch panel for each gear if so anyone have pictures of factory od set up going to put in 64 | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | check out Jolly Goodfellow's GMC page - you can get there from the links page. Those transmissions have an OD that is controlled by an electric solenoid - the OD assembly is added to a standard transmission. Please use capitalization and punctuation - it makes it so much easier to sort out what is being asked.  | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | There are multiple ways of hooking them up. Anywhere from original to toggle switches.
But to answer your question on how to kick it into over drive you will be shifted into 3rd gear then let off the gas at around 29 mph then give it the gas. You will feel it kick in. Your rpms will drop.
This is on the 50s model 3 speed with OD.
Best of luck.
Dennis -there is nothing stronger than the heart of a volunteer-
