0 members (),
128
Mod | | | Forums66 Topics128,127 Posts1,056,680 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#18835 04/03/2002 5:18 PM | Joined: Oct 2001 Posts: 7 Member | | Member Joined: Oct 2001 Posts: 7 | I have a 235 and 2 exhaust manifolds. One has a completely frozen heat riser and the other is movable but still quite hard to turn. Is there a way to free them up, or am I S.O.L.? | | |
#18836 04/03/2002 5:58 PM | Joined: May 2001 Posts: 41 Member | | Member Joined: May 2001 Posts: 41 | give a doseing of penatrateing oil.wiggle oil agaig let sit for a few hours. oil again and wiggle some more.keep doing it untill it frees up. A little tapping with a small hammer will help too. Just don't hit it real hard because you could break the manifold. Good luck and persistance will help too. -------------------- 37 Chevy 1/2 Ton
37 Chevy 1/2 Ton 86 Chevy Blazer 98 Drudge 24 valve Cummins One worn out Timberjack
#18837 04/03/2002 11:55 PM | Joined: Jan 2001 Posts: 47 Member | | Member Joined: Jan 2001 Posts: 47 | Travis Woodhicks advise is just what mu 56 Buick shop manual says to do but they say lube with graphite after. I used some heat resistant gold colored stuff from NAPA to lube my Buick and the valve has worked for two years so far. | | |
#18838 04/04/2002 3:21 AM | Joined: Jun 2001 Posts: 11 Junior Member | | Junior Member Joined: Jun 2001 Posts: 11 | Woodhicks advice is what worked on my '54 3100 235. I am fortunate to have a buddy with plenty of experienced on old restorations.
Be very patient and use a tiny hammer, it will free up.
Thunder 54 | | |
#18839 04/05/2002 6:56 PM | Joined: Dec 2001 Posts: 2 Junior Member | | Junior Member Joined: Dec 2001 Posts: 2 | I was unable to free mine (54 1st 235) with a hammer. It had been rusted fast for I don't know how long. When I had the carb off for a rebuild I blew a lot of air through the manifold and cranked the engime a few times to expell the fumes then hit the manifold and riser shaft with a torch. After a few minutes I got a little wiggle. I removed the heat and just worked it back and forth until I had full travel. I have not lubed it but perhaps I will now that I read the other posts. | | |
