1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
Junior Member
Junior Member
Hi can some one tell me what this is and it's costs? I know it was on the idle arm of a '51 Chevy car.
I think it is a quick fix for a bad idle arm.
Miller
Front view
From the top
Miller
Miller- That's all I can figure is that when the idler arm got loose, you could use this to squish it back down to tight again. Personally, I would rather replace the worn part.
To be long remembered as he's cruising in
The Passing Lane
Junior Member
Junior Member
Barry that is what I make of it ..I would like to know what it is called and if it is worth any thing?...Thanks for you input...Miller
Miller
H Online: Content
That looks like a Pitman arm puller, but it's such a light-duty model, I doubt if it would survive working on a really tight one.
Junior Member
Junior Member
Hi it does look like that tool but I know for sure it was used to assit the bad idler arm. I have seen these before years ago. I have forgot what these are called or who sold them...Thanks for your input...Miller
Miller
V
V Offline
Thats exactly what it is a cheap quick fix at one time you could buy these and other such gimmicks from places like JC Whitney.
V6 jimmy is exactly right, that gadget was used for cobbling a bad or loose idler arm back together. I had a 1952 Chev 4 door back in 1965 that I drove back and forth to work, and my idler arm jumped off when I crossed some railroad tracks. The car went bowlegged, and we ended up jumping the curb & almost hitting a cop car parked in a gas station.
I bought one of those things at Western Auto, put it on, and drove it until the doors fell off.
Junior Member
Junior Member
Hi fredstev can you tell what it is called and is this part still sold by the auto store? Thanks
Miller
I'm sure that they're no longer made, the legal liabilities would scare anyone in their right mind off nowdays. If I were you, I would just replace the worn parts. Check under "links" for suppliers like bowtieparts and chevy duty, etc.
Couldn't tell you the proper name either, but it was cheap - something like $5.95 back then.
Check this out:
Idler Arm repair kit $19
Frank
