0 members (),
140
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 7 Junior Member | | Junior Member Joined: Aug 2004 Posts: 7 | Hi can some one tell me what this is and it's costs? I know it was on the idle arm of a '51 Chevy car. I think it is a quick fix for a bad idle arm. Thanks Miller Front view From the top
Miller
| | | | | Joined: May 2000 Posts: 424 Shop Shark | | Shop Shark Joined: May 2000 Posts: 424 | Miller- That's all I can figure is that when the idler arm got loose, you could use this to squish it back down to tight again. Personally, I would rather replace the worn part. | | | | | Joined: Aug 2004 Posts: 7 Junior Member | | Junior Member Joined: Aug 2004 Posts: 7 | Barry that is what I make of it ..I would like to know what it is called and if it is worth any thing?...Thanks for you input...Miller
Miller
| | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | That looks like a Pitman arm puller, but it's such a light-duty model, I doubt if it would survive working on a really tight one. Jerry
| | | | | Joined: Aug 2004 Posts: 7 Junior Member | | Junior Member Joined: Aug 2004 Posts: 7 | Hi it does look like that tool but I know for sure it was used to assit the bad idler arm. I have seen these before years ago. I have forgot what these are called or who sold them...Thanks for your input...Miller
Miller
| | | | | Joined: Jun 2005 Posts: 221 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 221 | Thats exactly what it is a cheap quick fix at one time you could buy these and other such gimmicks from places like JC Whitney. | | | | | Joined: Aug 2005 Posts: 157 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 157 | V6 jimmy is exactly right, that gadget was used for cobbling a bad or loose idler arm back together. I had a 1952 Chev 4 door back in 1965 that I drove back and forth to work, and my idler arm jumped off when I crossed some railroad tracks. The car went bowlegged, and we ended up jumping the curb & almost hitting a cop car parked in a gas station.
I bought one of those things at Western Auto, put it on, and drove it until the doors fell off. | | | | | Joined: Aug 2004 Posts: 7 Junior Member | | Junior Member Joined: Aug 2004 Posts: 7 | Hi fredstev can you tell what it is called and is this part still sold by the auto store? Thanks
Miller
| | | | | Joined: Aug 2005 Posts: 157 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 157 | I'm sure that they're no longer made, the legal liabilities would scare anyone in their right mind off nowdays. If I were you, I would just replace the worn parts. Check under "links" for suppliers like bowtieparts and chevy duty, etc.
Couldn't tell you the proper name either, but it was cheap - something like $5.95 back then. | | | | | Joined: Aug 2004 Posts: 399 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 399 | | | |
