2 members (Hugh63c10, Phak1), 260 guests, and 3 robots.
Topics128,089
Posts1,055,988
Members48,430
#187838 08/17/2005 7:54 AM
Junior Member
Junior Member
A friend of mine has a front end off a '85 silverado, and he'll give it to me free. Can I use parts off it on my 65 C-10? All I really want is the brakes and mabey the powersteering, so my question is are they easily bolted on? Or if some fabrication is needed, how much? Thanx for all the helpful advice.
#187839 08/17/2005 7:24 PM
There are a couple outfits that make it possible to incorporate the '88-up suspension. But if you're only after the brakes and steering, I don't think I'd go through the trouble (it doesn't bolt right on). Get a kit designed for your truck.
#187840 08/17/2005 7:48 PM
Junior Member
Junior Member
he mentioned an 85.. do a search for crossmember and you'll find lots of stuff
1966 SWB
#187841 08/17/2005 8:48 PM
Duh, yeah I see that now. Sorry, for some reason my "late-model" wasn't working when I replied.
#187842 08/17/2005 10:01 PM
Junior Member
Junior Member
Yeah I saw a topic saying that 72-87 c10 IFS will bolt right up, but (forgive my ignorance) my friend has a Silverado, is that the same thing?
#187843 08/18/2005 2:44 AM
Z
Z Offline
the crossmember and steering will mostly bolt up.no welding.you will need a "rez" adapter to mount the later steering box.minor welding.
#187844 08/18/2005 3:50 AM
Junior Member
Junior Member
Could not find any mention of this adapter using the search on this site, could you mabey give me a few more details?
#187845 08/19/2005 1:16 PM
I used the REZ engineering power steering adapter on my 64. I used the box from an 80 model, which should be basically the same as yours. No welding, simple instructions. I have to say it is the best improvement i have done to my truck besides disc brakes. You can use the frontend from the 85 model. Some people swap crossmembers, some just swap the parts. This falls some between simple and agrivating, but not straight foward. I swapped in a 71 frontend under my 64. It is worth the effort. If i was to do it again i would go with a later model because of the rubber control arm bushings. They ride better and are a whole lot cheaper to replace. Let me know if i can help.
