4 members (69 coupe, 68ironhead, Maybellene, 1 invisible), 65 guests, and 6 robots.
Topics128,064
Posts1,055,861
Members48,428
#187801 08/16/2005 6:43 PM
Y
Junior Member
Junior Member
Y Offline
I have started to make a engine swap on a 29 chev trk I would like to keep the original bell housing i'm swaping out a 194 to a 235 seems to be some serious changes any info would be great thanks woodie
woodie
#187802 08/16/2005 6:49 PM
Yes, the bolt pattern is differant between the two. The 235 does match up to the 216 bolt pattern, though.
Paint & Body Shop moderator
#187803 08/16/2005 11:18 PM
Check out the tech references etc. There are some discussions on this.
1951 1 Ton Completed
#187804 08/17/2005 1:51 PM
Y
Junior Member
Junior Member
Y Offline
Thanks for ur imput think ill have to give up on the plan as there are to many things that wont work like the most important thing the bell i no that the 216 will fit the prob is this old trk has the clutch and brake pedal mounted to the bell without using the org bell it makes the progect a nightmare thanks for your help woodie
woodie
#187805 08/17/2005 10:26 PM
I
I Offline
my 44 1.5 ton had the pedels mounted on the bell
rh
#187806 08/18/2005 1:16 PM
Y
Junior Member
Junior Member
Y Offline
thanks ill have to see if i can find one around here and takea look at it mine bolts to the back of the bell with three bolts just above where the clutch fork comes out .There are a lot of changes from my 29 to everthing i look at but haveing the the pedals so i could get them on would get me going foward thanks for ur help Woodie
woodie
