0 members (), 83 guests, and 0 robots.
Topics128,049
Posts1,055,740
#18771 07/09/2002 5:41 AM
My old carter carburetor is just not what she used to be. Does anyone know of a good replacement for a 2 barrel carter WCD with 4 bolts that would bolt onto my existing manifold?
It is for a '62 261ci 6.
#18772 07/10/2002 5:33 AM
I'm not sure if the bolt spacing is the same, but maybe a Rochester 2G two barrel carb. would fit.....................there should be plenty around at wrecking yards or Pick-N-Pull. You probably want the earlier, small one (280 cfm) for your 261, not the larger one (435 cfm) found on mid-seventies Camaro 305 V-8's. smile
*** GMC ***
