2 members (cmayna, Wickedbass),
71
Mod | | | Forums66 Topics128,086 Posts1,056,101 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 21 Junior Member | | Junior Member Joined: Nov 2004 Posts: 21 | Where can I get the original tire size for the 63 chevy fleet swb truck? I'm not sure what size tiere to put on this thing fojr the street.
thanks
Thanks, Ivor
63 chevy short/fleet 292/4speed under construction
| | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | Does the truck have any tires on it now? What size are they? Are the rims original? What size are the rims? A quick guess might be a 7.00/15 or in radial speak something like a 205/85R15. That would be close to a stock size. Of course if you wheels are the optional 16 inch wheels then buy 16 inch tires. We need a little more info from you. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | 6.70x15 was the standard size, optional bigger sizes for higher GVW rating
Bill | | | | | Joined: Nov 2004 Posts: 21 Junior Member | | Junior Member Joined: Nov 2004 Posts: 21 | Thanks for tthe info. The truck now has a mix up set of aggressive bald mud tires that extend past the wheel well. The truck has stock 15" rims and I want to put stock size tires that will be good for street driving and not pulling stumps on the farm.
Thanks, Ivor
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I have 225/75/15s,, real close to the OE 7.00/7.50/15, speedo is within 1 mph so they are close to stock height. Brian | | |
