| | | Forums66 Topics128,151 Posts1,057,004 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | I have the inners fenders finished and am ready to mount the rubber seal around the innder fenders for my '60. The original ones were stapled with a SERIOUS metal staples. Does anyone make a stapler like that anymore or do I just use some 3M rubber seal type glue?
Jake | | | | | Joined: Jun 2002 Posts: 81 Member | | Member Joined: Jun 2002 Posts: 81 | I just put the rubber on my '54 inner fenders. I used some glue and then some modern - not as heavy staple that came with the rubber from Chevy Duty. I just used needle nose pliers to thread the new staples into the old holes, poking it through the rubber is the hardest part. I used some dental tools I had picked up at a yard sale. Once you have poked the two staple sides through, just bend them over with larger pliers. It worked well in conjunction with the glue. Good Luck  | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | Mainer54,
Are these a Chevy Duty Product or something from a hardware store? Do you have a part number for these staples?
Jake | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I used Arrow T50 staplegun staples, put them in w/needlenose pliers. Sized just right. Brian | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | Thank You! That'll save a few bucks!
Jake | | |
