5 members (J Lucas, Lugnutz, Otto Skorzeny, Steelonsteel, Rich'sToys), 94 guests, and 2 robots.
Topics128,211
Posts1,057,472
Members48,473
1 Offline
hey guys i wanted to see if some of you could help me with this one i need to find out what gears i have in my rear axel ,thx donavan
The best, easiest and most accurate way to check rear gear ratios is to jack the truck up. With both tires just clearing the ground, put a piece of tape on the inside of both tires. Put a piece of tape on the ground next to each of the tire tapes. Put a piece of tape somewhere on the driveshaft or yoke so that it hangs straight down and is easy to see. Get a helper on the other tire and turn both tires in the same direction, at the same time. Count the number of turns on the drive shaft, until the tires are back to the tape marks and have made one revolution. If you should happen to have posi, both tires will turn together in the same direction. If the drive shaft turns past 3 turns and ends up on top, it has 3.50:1 gears. If it turns just shy of 4 turns it has 3.90 gears, or just past 4 turns, it's 4.11
'67 GMC 3/4 292 4spd
Or you can take your AXLE apart and see if the ratio is on the ring gear.
Another quality post.
Real Trucks Rattle
and some might be stamped on top of the rear housing,,
Redryder pix
My Hotrod
