| | | Forums66 Topics128,056 Posts1,055,800 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#18675 11/22/2003 4:54 PM | Joined: Nov 2003 Posts: 14 Junior Member | | Junior Member Joined: Nov 2003 Posts: 14 | I was just given a '62 panel truck. It has 1982 plates on it, and ran when parked. The guy who owned it put a four speed transmission in it. The one with the grandma first gear. It seems to be stuck in second gear. anybody know of a trick to get it unstuck? | | |
#18676 11/23/2003 2:42 AM | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | I don't know a trick, but what I did with my 50 that had been setting outdoors for about 20 years and was "stuck" in neutral was remove the floor board panel and take the top off of the trans. The shifter mechanism is all in the cover. There are 3 shifter rods or shafts, one for 1 & 2, one for 3 & 4 and one for reverse. Each has a yoke or fork that slides the gears forward and back. The reverse fork is much smaller and engages a lever that slides the reverse gear. 1-2 and 3-4 shafts have 3 detents or grooves. Above the shaft in the cover is a steel ball and detent spring for each shaft to hold it in place... Probably the detent spring/ball or the shifter shaft is rusted, or stuck in place. With the cover off you can inspect (you can't really see the springs and balls) to see what's rusted, stuck, damaged - and just clean and lube everything with diesel, penetrating oil, WD-40...and get all the shafts sliding back and forth. With cover off you can inspect the gears themselves and slide them back and forth. Maybe drain and refill the oil while the top is off. Be sure the gears are in neutral and everything is lined up and put the cover back on. Good luck.
Professional Novice
#18677 11/23/2003 9:16 AM | Joined: Nov 2003 Posts: 14 Junior Member | | Junior Member Joined: Nov 2003 Posts: 14 | cool, thanks. I'll give it a shot. | | |
