8 members (rfs56trk, Frank50, BarryP, Gazz, UtahYork, Jon G, Ole49GMC, 1 invisible),
106
Mod | | | Forums66 Topics128,134 Posts1,056,740 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 120 Member | | Member Joined: Sep 2004 Posts: 120 | Does anyone out ther have a nailhead powered truck. I have head of them but have never seen one. I have a 1959 gmc and would like to put a 401 nailhead I have in to it. I just want to see how the factory did it. | | | | | Joined: May 2004 Posts: 124 Member | | Member Joined: May 2004 Posts: 124 | That is a new one on me. I have never heard of a nailhead engine. What is it?
I like old trucks
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the factory didn't do it - GMC didn't use Buick's - not sure how they mounted the Pontiac 336 that was the V8 for 59
Bill | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I agree with Red. Alot of them were used for engine swaps in the 50s-60s. A nailhead engine is a Buick v-8 up to 67. So named because they had a small exhaust valve Kind of looked like a nail.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I read where the valve stems come straighr out of the head as apposed to on an angle, and thus the term nail head. | | | | | Joined: Apr 2005 Posts: 5 New Guy | | New Guy Joined: Apr 2005 Posts: 5 | According to a guy who worked in the factory (Janesville probably), GMC used Buick and Olds V8s in some big trucks.
They apparently were unreliable in big trucks. | | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | | | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | The Pontiac engines in GMC's used a single front mount,similar to the early 60's Chevy V-8's in the one ton and bigger trucks,only it didn't fasten to the block,but rather it attached to two ears that were located on each side at the bottom of the timing cover. When I installed the 1968 400 in my '57,the same mount fit my new engine,making that part a bolt in. The rear of the engine used an iron bellhousing with mounts,also similar to the Chevy V-8 set up,only with the early Pontiac block pattern,which changed to the BOP pattern in '64. I was unable to find an iron bellhousing with the mounts and the later block pattern,so I made a plate to fit the original mounts and fit between the bellhousing and the transmission,and I used a standard aluminum Pontiac manual bellhousing;not the strongest set up,but I haven't broken it yet,and I've given it reason to break. | | | | | Joined: Oct 2003 Posts: 185 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 185 | Originally posted by Jason Davies: According to a guy who worked in the factory (Janesville probably), GMC used Buick and Olds V8s in some big trucks.
They apparently were unreliable in big trucks. I've seen larger TF trucks (bigger medium duties) for sale that had Buick motors. And that age would place those motors in nailhead territory. Mike Boteler has two Buick powered trucks. | | | | | | Anonymous Unregistered | | Anonymous Unregistered | The 322 cubic inch engine that was listed as an option for the larger Task Force trucks was a Buick engine. Not sure if this is considered a nail head or not. | | | | | Joined: Feb 2004 Posts: 29,841 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,841 | The 322 engine was used in the Buick passenger car from 1953 through 56, in several HP ratings. Yes, it was the "nail head" design, with the vertical sides on the valve covers. Jerry
