2 members (2-Ton, 1 invisible),
108
Mod | | | Forums66 Topics128,034 Posts1,055,546 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#18618 07/10/2002 6:42 PM | Joined: Jan 2002 Posts: 7 Member | | Member Joined: Jan 2002 Posts: 7 | Got an oil leak at the rear of the engine on my 1966 250 c.i. three speed. I suspect the rear main bearing seal is bad. That is probably what is causing the clutch to slip. Here is the question. How do I know what size pressure plate to order ( 10", 11" , or 12" ) without tearing it apart. I would like to have the parts on hand when I go in. | | |
