1 members (Hotrod Lincoln), 56 guests, and 3 robots.
Topics128,090
Posts1,056,024
Members48,432
#185506 07/15/2005 7:45 PM
I
Junior Member
Junior Member
I Offline
followup to an earlier post.
Looking to make my '53 chev 1 ton road worthy (safe on the road and usable at highway speeds).
Anyone with strong opinions on whether it is better to put the cab on a newer chassis (what might be a good donor vehicle) or to just use the old chassis and replace the front and rear?
Which might be easier (have limited ability) and cheaper (wife says I have limited money).
Any hints, tips or opinions would be welcome as I am new to this.
Ian Horner
I vote to update the original chassis due to your limited ability. Good luck.
Phil
Never hold your farts in. They travel up your spine and into your brain...that is where crappy ideas come from.
Assuming the original frame is sound (in this part of the world that has to be checked) I'd say updating is the correct approach.
V
V Offline
The frame on your truck is much sturdier than any of the new junk they make.rebuild the stock front suspension add disc brakes possibly install a later rear end if you want higher gear ratio for Hiway cruzin
