| | | Forums66 Topics128,014 Posts1,055,333 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#18545 07/13/2002 4:02 AM | Joined: Jun 2002 Posts: 53 Member | | Member Joined: Jun 2002 Posts: 53 | Can someone tell me what this engine is code:B 34707228. I was told its a 58 GMC 336ci. I am not sure and where can I buy parts for it. I will be rebuilding it. Thank you, Bob | | |
#18546 07/13/2002 4:11 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Which modeln of engine is it? (inline 6 ,,V-8)
#18547 07/13/2002 5:10 AM | Joined: Mar 2001 Posts: 327 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Mar 2001 Posts: 327 | It is a 5.5L V8. I would check this site and give them a call. if they don't have what you need they will probably know where to get it. Go slowly on the rebuild. do it right the first time. Flatlander Racing
Oly in Oregon Rest in Peace1945 GMC COE Victory Truck 1953 Willys CJ3B 1955 Chevy 1st series 3/4-ton 1958 WIFE Last series Never say "Whoa" in a mud hole
#18548 07/13/2002 7:53 PM | Joined: Nov 2000 Posts: 427 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 427 | It's a GMC 347 which was an optional motor on the T production 100 through 250 series trucks only. Hope this helps. OldGMCtrucks.com - \'55-\'59 Serial Numbers | | |
#18549 07/13/2002 10:45 PM | Joined: Mar 2001 Posts: 316 Member | | Member Joined: Mar 2001 Posts: 316 | That's what I thought: Poncho V-8! 347's and 370's and early 389...........I had a complete 370 with flat top pistons (hydramatic) from a '58 GMC truck, even had the bellhousing and flywheel with it. I gave it to a buddy of mine who is into Pontiacs.
*** GMC ***
