3 members (carbking, DaveV, 1 invisible),
81
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,136 Posts1,056,427 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2004 Posts: 7 Junior Member | | Junior Member Joined: Oct 2004 Posts: 7 | Can anyone tell me if there is a kit available to put tube shocks on my 48.Jim Carter and Chevy Duty say their kits will only work on 1/2 tons but didnt say why.Thanks
Joe Bruno
| | | | | Joined: Jul 2005 Posts: 15 Junior Member | | Junior Member Joined: Jul 2005 Posts: 15 | It must work. They look exactly the same on my 53 3/4. Try Patricks in AZ, and ask him. I ran into the same problem with J. Carter's people, and see it all the time at the parts houses. If it aint in their catalog it does not exist. I have a set of modern tie rod ends for my rig that came about by searching the catalog at Kragen and matching the original O/D and taper. Too bad Jim Carter shut down his tech line, they knew their stuff, at least 7 years ago they did. | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | When I looked up the application recently at www.gabriel.com they showed the same shock for 1/2 and 3/4 ton. They used to have a different rear shock. You can get them through a local dealer. My local parts store had the front shocks in stock, but that was 8 years ago.
Fred 52 3600 69 C-10
| | | | | Joined: Oct 2004 Posts: 7 Junior Member | | Junior Member Joined: Oct 2004 Posts: 7 | Thanks-ill keep digging and see what they say.
Joe Bruno
