| | | Forums66 Topics128,087 Posts1,055,999 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 27 Junior Member | | Junior Member Joined: May 2005 Posts: 27 | I've got a 62 Chevy Stepside with a standard shift 3spd. This means that the brake and clutch master cylinders are the same unit. I'd like to convert to disk brakes since the old brake pads are most likely the origionals and this will be my daily driver. Here is the problem. With the clutch and brake sharing the same unit I can't get a brake master cylinder with a booster for using disks. What do you all suggest? I'm not opposed to changing the clutch set up, as it is slipping a bit right now anyway. Thanks.
Priorities make dreams happen.
| | | | | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | www.mpbrakes.com has what you need if your well off. | | |
