3 members (Gdads51, NorCal52Suburban, Shade Baby), 75 guests, and 2 robots.
Topics128,037
Posts1,055,582
#184047 06/19/2005 10:48 PM
Junior Member
Junior Member
I have read several of the messages on this topic and am confused. I need tires for my '54 3100. The existing tires are P215 75 R15. this would lead me to believe that I have 15 inch rims. (The rims measure 16 + from outside to outside.) Is this stock or were the rims changed somewhere along the way? My owner's manual says the tires should be 6.00-16-6 This would appear to need a 16 inch rim however I am not familiar with the rest of the designation. What size rim was provided stock on the truck? Would it be OK to put a larger diameter tire on the existing rims? Thanks
#184048 06/19/2005 11:15 PM
You've got 15" tires and rims.
Rims are properly measured across where the tire bead seals. 16" tires will not mount on those rims.
#184049 06/19/2005 11:36 PM
Andy,
6.00-16 (4.5" rim section), 6 ply rating tires were standard (16" rim)
6.50-16 (5" rim section), 6 ply rating was a common factory option (16" rim)
15" (5.5" rim section), 6ply rating was also an option in 1954 (15" rim)
The rim section, I think, is the width of the rim at the lower inside edges.
You can put a larger outer diameter tire on a rim (within reason; maybe up to a 33" loaded outer diamter) but the inner diameter of the tire must match the rim diameter. If I am wrong, we can be sure that someone will post a correction.
Tim
